Vagabond Mini Turning on then immediately off.
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4957
Author:  stevealejandro7 [ Sat Sep 03, 2016 3:04 pm ]
Post subject:  Vagabond Mini Turning on then immediately off.
My vagabond is fully charged. When I turn it on, I see 3 solid green lights, but immediately goes off after that. Is it busted? :( I can turn it on again and again, but the LEDs only stay light for about a second. :(
Author:  Technical Support [ Tue Sep 06, 2016 11:45 am ]
Post subject:  Re: Vagabond Mini Turning on then immediately off.
Without knowing the age of the Vagabond, it could be the end of life for the battery, or there may be an issue in the inverter. If you have, or have acess to, another battery and/or inverter, you can swap components to follow the problem.
If the battery is more than 3-4 years old, you can try a new battery, as you are going to need one soon anyway.
If a new battery doesn't work, or if you want to bypass that step, you can send the unit in to us for inspection. I would contact our repair depatment directly for costs.
