Einstein light is firing irregularly and then not at all.
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4960
Author:  jaychatzkel [ Wed Sep 07, 2016 5:28 pm ]
Post subject:  Einstein light is firing irregularly and then not at all.
My Einstein light had been working fine and is now firing irregularly but not firing when I press the shutter. I thought the problem may have been the trigger or the connection with the line going to the trigger. This has never happened before. I turned off the light to see if it had overheated.
Any idea of what is going on?
Thanks
Author:  Technical Support [ Thu Sep 08, 2016 10:41 am ]
Post subject:  Re: Einstein light is firing irregularly and then not at all
How are you triggering?
Have you tried using the standard sync cord to see if the problem persists?
Does the flash fire consistently from the test button on the back panel?
