new X1600 Sync cable input not working
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=57
Author:  tomcouture [ Sat Dec 19, 2009 6:08 pm ]
Post subject:  new X1600 Sync cable input not working
Connected pocketwizard to the input on the newest x1600 I just got and it doesn't respond to any test firing. Works fine with my other new x1600. I guess this means I'm going to have to send back for repair or replacement?
Author:  Technical Support [ Mon Dec 21, 2009 10:05 am ]
Post subject:  Re: new X1600 Sync cable input not working
Are you using the same cord on both lights when testing the PW? Also, when you unplug the sync cord, will the flash fire? Does the flash work with the stock sync cord?
TS
Author:  tomcouture [ Mon Dec 21, 2009 12:09 pm ]
TS
Of course I used the same cord, same pocketwizard, same AC cord for both lights...for the heck of it I just tried the stock sync cord connected to my camera and nothing happened when I pressed the shutter.
Author:  Technical Support [ Mon Dec 21, 2009 12:34 pm ]
That sound like something that does not have a user solution. Please contact us to make arrangement to correct this issue.
1-800-443-5542
or info@paulcbuff.com
TS
Author:  tomcouture [ Mon Dec 21, 2009 1:37 pm ]
1-800-443-5542
TS
I already did on Saturday, no response yet about an RMA. I still have the box it was sent in.
