| Cyber Commander https://paulcbuff-techforum.com/viewtopic.php?f=8&t=60 |
| Author: | simmons3 [ Sun Dec 20, 2009 7:39 pm ] |
| Post subject: | Cyber Commander |
How do I activate channel 1. The bar at the bottom is always gray. I can get channel 2 and 3 to be green when I set them up. I do not htink I did anything differently on channel 1, but I must have. Thanks Will |
| Author: | Technical Support [ Mon Dec 21, 2009 10:02 am ] |
| Post subject: | Re: Cyber Commander |
in "set up">"light settings" make sure under power is marked "on" and not "standby". also be sure you remain in channel 1 and are nto switching channels, thinking you are changing parameters. TS |
| Author: | simmons3 [ Mon Dec 21, 2009 10:42 am ] |
Thanks, That did it. Will |
