 [ 6 posts ]
Fri Dec 18, 2009 11:31 am
When I change the batteries in the Cyber Commander, it won't come back on unless I remove the memory card and re-insert it. Sometimes I have to do this several times before the unit will activate. Is there something wrong or will this be corrected in the firmware?
I also have the occasional freezing that you say will be corrected in a firmware update.
Fri Dec 18, 2009 4:45 pm
both should be addressed in the firmware update and update process
Sat Dec 19, 2009 7:42 am
And how would one get this update?
Mon Dec 21, 2009 10:51 am
We are working on that now. I will post either a new topic and/or individual replies when we are ready to release it.
Mon Dec 21, 2009 2:59 pm
If you decide to distribute the revised firmware via individual replies, please add me to the list.
Thanks,
Sam
Wed Dec 23, 2009 2:05 pm
Not working after battery change... FWIW had same issue ....pulled out memory card and put back in and Cyber Commander works fine... something to try.... it worked for me....
 [ 6 posts ]
Users browsing this forum: Google [Bot] and 24 guests
