Tue Dec 29, 2009 2:13 pm
Hi guys,
I bought a Vagabond II used. Now the problem is when I plug in the
charging cable - all it does it shows a red light and the fan turns on for a few seconds then
the light and fan goes off and turns on a second after.
When I detach the charging cable and turn the Vagabond II in either fast or slow mode - it's
beginning to beep constantly, the green led (near the fast,off,slow button) is lit all the time and the red charging led is blinking constantly.
any solution/suggestion for this problem?
please help a wannabe Vagabond user
thanks in advance
Schatti
p.s.: all cables are seated properly and the fuses are not blown
Tue Dec 29, 2009 5:24 pm
that sounds like a sulfated battery, which is quite possible, especially if used (you dont know the care proceedures of the previous owner). Please contact Customer Service to arrange replacing the battery.
TS
Users browsing this forum: Majestic-12 [Bot] and 180 guests
